Removing stuck rotors
I have 97 XLT 4WD. The rotors were unbelievably stuck.
Couple of factoids:
1. Rotors are cheap ~$30 each, buy new rotors.
2. Removing with a big hammer is the often suggested approach.
3. Mine were so stuck, couldn't get enough backswing to get them off.
4. Eventually came off after beating for about 1.5 hours -- bad. Don't listen to that advice.
5. I put a three jaw puller on the edge of the rotor, center in the stack of washers in the center of the hub. I tightened considerably, tighter, tighter, rotor wouldn't come off. Left the puller under tension and hit the rotor lightly with a hammer, the rotor flew off about 2.5', no exaggeration. Good thing I happened to be standing up to the side since my back was hurting. Unfortunately, this data applies to the rears, because the fronts were beaten mercilessly with a hammer. The rears look just like the fronts, though, so it should work on the fronts exactly the same.
6. Last rear wheel, applied 3 jaw gear puller, applied very slight pulling pressure, hit the back of the rotor a couple of times with a rubber hammer, success. Just broke free by popping ~1/8", enough to tap them off the rest of the way. That rotor could possibly have been reused.
7. Believe me, all of my rotors were extremely stuck.
8. The front rotors are slightly cheaper than the back ones, which are ~$30+, because the rear rotors contain a drum for the parking brake.
9. You can check the prices of the rotors at Autozone online, if you want.
10. My rotors had these little metal clips over the wheel lugs, remember to remove those first, don't cut your fingers.
11. I don't know why this method isn't the recommended forum approach, and so i cannot supply a warranty with this technique, especially in terms of its impact on bearings, etc. However, I will "virtually guarantee" that the rotors will come off with this method, or double my advice back to you.
12. Ford manual says, in summary "remove clips, then remove rotors". No mention of the ungodly force required to remove them if they're 9 years aged.
13. A large 3 jaw gear puller is available at Autozone for ~$18.
