allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
This morning after breakfast while it was cooler than normal I decided it would be a good time to install new rear brake pads on my white 1997. I recently had found a receipt from not too long ago showing that all of the pads had been replaced including turning the rotors had been done. I decided that I would just install new pads for now and the next time around replace the brake rotors. About a year ago I had purchased a set of semi-metallic Bosch pads for the front and 2 days ago while waiting on the rear pads to arrive replaced them. While the wheels were off I visually checked the front undercarriage and physically checked the front wheel bearings.
Now to the back brakes. I bought a set of Bendix semi-metallic pads and the quality looks very good as well as did the Bosch pads. So far I haven't found any marking on any of the parts or packing that says made in C hina. The bendix pads came with new anti-rattle hardware.
Picture of the old pads and the new ones. The old ones are less than half used so I will save them for my Mountaineer.
The rear pads are rights and lefts and do have tops and bottoms. I'm pointing a screwdriver at the notch on the bottom of the pad.
I was checking dates on the tires and they are one week from being 3 years old. Incidentally I spotted something metal in the tread of the right rear. Looks like a trip to the tire store soon.
I was able to do this at home with limited tools. I used a jack and stand, lug wrench,10mm to break a loose the caliper bolts a flat blade/tip screwdriver to help pop the pads out and a "C" clamp to push the caliper piston back in. If this is going to be your first time to do this task only have one caliper loose while you are compressing the piston!
EDITED June 2025: Pads lasted 5 years and 70k miles!
