1995 Explorer
- January 21, 2011
- Western Springs, IL
- 95 XLT '97 XLT '97 Mounty
I am currently changing the valve cover gaskets on my Ex. While i have the intake off i was plannin to change the pcv valve. I have followed several threads here and the place where it would normally be located is empty. I placed the new valve in and it fits perfectly but there is not a line to connect to it. I located the spot on the steel lines where the pcv hose would normally hook up along the passenger side fuel rail, but the place it would hook up does not have a fitting, rather the two lines are joined together with a u fitting. I don't believe that this intake has every been off before and it looks original.
Is it possible that my ex did not come with a pcv valve from the factory? The truck runs fine and does not throw any codes. Like I said above i found where the valve would go at the back of the intake, but there is nothing there, just an empty space. I consider myself fairly mechanically inclined, but i must say that I am stumped by this. I thought a 1997 would have had a pcv valve.
