jjvanderlaan
- August 23, 2015
- Grand Rapids, MI
- 1998 Explorer
I've been having an issue with my 1998 Explorer, it's an AWD V8 5L. As I accelerate it has been making a knocking/banging sound somewhere in the driveline. As I accelerate it knocks hard several times, and then starts to go away as I gain speed. I have inspected all the usual suspects: driveshaft CV joint, CV axles, u-joints, etc. and all seem to be in good shape. The only thing I did notice was that the spline on the end of the front driveshaft was a bit loose, but not to the point where it would be skipping teeth.
I suspect the issue may be in the transfer case based on some reading I have done. I am thinking loose chain in the transfer case or viscous coupling?
With the front drive shaft removed, the sound goes away. Currently I have both drive shafts removed and the case seems to have more slop than it should. See the videos below. I am not familiar with transfer cases so I am unsure if there should be this much play? Would this be a loose chain or viscous coupling issue based on what I am describing?
Thanks
Jon
Thanks
Jon
