SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
Nice clean pieces.
Thanks. I ran into that the first time i got this running. The water pump bolts that you can buy at AutoZone is a hodgepodge of odd length bolts and you wind up not using half of them. I was just hoping maybe one of you guys knew the secret source. My intent to basically have this motor all ready to go, so I can drop it in so when I pull the other one out, I can turn around and put it right back in the same day.There isn't really anything exactly like the original WP bolts. Your best bet is to carefully measure the lengths, and find what you can from grade 5 bolt sources. The bolts with threaded ends and nuts for hold downs, those you have to do without. I have bought 3-4 bolt sets that looked good in pictures, but none had the right sizes in them.
No kidding.I have that ARP set too, I think maybe two of those bolts are close in length to the originals. I wrote down what they were when I did my WP, but I used as many of the old ones as I could. I replaced one from Home Depot, that one bolt was replaced before and was the wrong thread pitch(metric not SAE). The OEM are the very best for size and function, we really do need ARP to reproduce those. I'd buy four sets if they made them.
Well for what it is worth I just sent a kit suggestion to ARP. Maybe they will read it and make all of us something we can use.There isn't really anything exactly like the original WP bolts. Your best bet is to carefully measure the lengths, and find what you can from grade 5 bolt sources. The bolts with threaded ends and nuts for hold downs, those you have to do without. I have bought 3-4 bolt sets that looked good in pictures, but none had the right sizes in them.
Thanks for the suggestion. I wasn't thinking in that vein. I'm going to order an ARP set this week. So I can get this motor ready to drop in. If any of them are wrong I'll pick them off the other motor.Arp sells a set
EBay has cheap sets
I used to have that from over 40 years ago, I'm sure I finally threw it away. That did work, but it was hell to remove, I used it on my Cleveland water pump at least twice(the WP went three times, the 2nd and 3rd were AutoShack lifetime junk). I also had to do the starter at least three times, again a "lifetime warrantee" lesson.I like blue. Easier to spot an oil leak. I use Indian head gasket shellac on everything so it doesn't leak.
