1998 Explorer. A/C blows hot all of the time. | Ford Explorer Forums
vacdude
Minnesota
'98 xlt
Hi - I just registered and have seen some posts regarding the Blend Door. Not sure if this is the problem with mine though. One day my ac was working just fine and next day it would only blow hot air even on Max AC. The posts regarding the blend door indicate that it will blow cool on Max AC if it is the problem but mine blows hot all the time.... Could it be a relay? Any thoughts? Thanks!!
Welcome to this forum! I've moved your thread into the A/C & heater section. You could tell if it's the blend door if the compressor's clutch is engaged without cycling, and it's blowing hot air out of the vents.
mine is currently doing this. i pulled my blend door servo off and found the top of the door axle is broken. some unbolt (kinda a pain) and some unclip (i was lucky) then you can put your finger in there and feel it.
