niknik01
- August 24, 2012
- Minnesota
- 1998 Ford Explorer 5L AWD
I have looked through the forums and found a few posts on this topic. But I still cannot figure out the problem.
My passenger window will go down from either the driver side window button or the passenger side window button.
I have taken off the door panel and tested the window motor. I separated the connector to the motor below the door handle multi-switch unit. This leaves two plug holes on the connector show and you can then get power to the motor. Applying 12v to this connector powers the motor.
Get a 12v booster charger, put a small nail in the large clamp POS and NEG jaws. Turn it on and touch POS and NEG nails into the plug holes. Careful you may get a spark. Depending on which plug you put the POS nail in the window should go up or down.This allows you to open or close the window with no problems. This is a great way to shut the window if the motor is ok and something else is wrong.
My window opens and closes no problem.
I have replaced the passenger window switch but I still have the same problem.
I have checked the wires in both driver and passenger do jams and there does not appear to be a broken one. I even check all the pins in the huge drum connector on the drivers side door.
So I am thinking I may have an grounding issue somewhere. Does the motor use the fact it is riveted to the door as a ground?
Any other ideas what could be wrong?
In another post I found the pinouts for the driver and passenger door. But cannot work out which is the ground.
Here's the link for that
http://www.explorerforum.com/forums/showthread.php?p=3029418#post3029418
