Hey Guys,
My wife's new (to her) '99 Eddie Bauer 4.0 SOHC has been a bit of a handful lately, here is the story:
Background:
The explorer has only been ours for a few months but always ran well(easy starts, smooth, good MPG). Last week it quit on my wife while she was driving on the highway, no clunks or clicks, just quit. A few weeks before it was starting at high idle for just a second and threw a code. I started checking for easy fixes; I replaced the idle air control valve(took care of the code), the TPS was good, inertia switch was good, it got a spark. Finally, I checked the fuel pressure and it was only 5 PSI, I pulled the fuel filter and when I primed the pump I could hold back the fuel in the rear hose with my thumb. So I had it diagnosed, great!
The Repair:
Last night we took down the tank (which was full) and put in an all new hanger assembly. Bolted everything back up and with a few turns of the key the PSI shot right up to 65 PSI.
The Problem:
I still have a no start situation. I checked the inertia switch last night and it is still good. I think that the problem must be tied in with the fuel pump because I do not think two independent things could fail at the exact same time on a otherwise healthy vehicle. My only thought right now is that I fouled the plugs from all of the cranking over the last week. I have never fouled plugs before on any vehicle so I do not know how probable this is. If it were my jeep I would just go ahead and replace them right now but they are so hard to access that I want to make sure before I do it.
My leading theory is that it is flooded in a bad way. I do not do much work on fuel injected cars so what is the protocol for going on from here? I tried starting with the pedal to the flood to no avail.
Any input is appreciated. I have been through a lot of other threads and have yet to find something for this engine that fits my situation, if I did miss a preexisting thread than I apologize for missing it. Thanks in advance for your help.
Background:
The Repair:
The Problem:
