philly5.0girl
- February 19, 2005
- Philadelphia, PA
- 1999 XLT
I just bought the car a week ago and have had no issues whatsoever with it until today. It's a 1999 XLT V8 AWD if that helps at all. Now I'm having an intermittent starting problem. Here's what happened:
Today we were running errands and went to several different places and on one of the last stops we went back out to the truck and it wouldn't start up. Battery was fine, radio and lights and everything worked but the truck just wouldn't not start or crank or anything. You could here a click and the fuel pump turn on as well.
Tried it with my key instead of my fiance's and then put it in neutral (its an automatic) and it started up but my fiance then turned it back off to try his key again and it wouldn't start up again, not even in neutral with either key.
Checked the fuses and they were fine. Got back in the truck, turned the key, voila! It started up just fine.
Drove to our next desination, turned off the truck then tried to start it back up again (right away this time) same thing, won't start back up. Went ahead and did our errand, came back out, same deal. He had to go back and get something so I reached over and turned the key and it started up just fine. Drove home, parked, turned off the car and waited a few minutes- then started it back up with no problem at least 10 more times.
I'm thinking maybe the ignition switch relay is going bad? Or maybe something funky with the antitheft system??
Any help would be greatly appreciated, I definitely don't feel like taking the bus to work on Monday if I can't get the truck to start!
Thanks,
Carly
Thanks,
Carly
