massacre
- January 24, 2018
- Massachusetts
- ‘94 Explorer
‘19 Nautilus
So I am going through this audio build in my head, and everything is seemingly OK
Except I am trying to figure out where to mount the amp.
Under back seats is a no go, if I never folded them down it would be fine but I do fold them down a lot during the warm weather. Folded down I can barely get my hand under there.
Thought about behind the passenger rear panel, but I replaced my headliner last year and getting those panels off is a pain the butt! Doing it once for the install is fine but having to pull that off every time I want to make adjustments to tune the amp sounds ridiculous.
Driver’s rear panel has a little door on it already but the jack and handle are there. under front seats MAY be a possibility but the amp is pretty large (5-channel) and I’m not sure about ventilation as the truck currently has no AC.
Back to the passenger panel-
I would like to run the power down the pass side anyways since that is the side the battery is on. I think I can go through a grommet behind the glove box and down under the bottom passenger door trims... and save all that cable going across the vehicle and back. it’s only 4 gauge so not too huge.
RCA cables-
I will have 6 of them, 4 for doors and 2 for sub. These are to be routed away from the power wire, correct? Thanks!
So like if I ran the RCAs down the drivers side of the trans hump, that would be fine? Thanks!
Also had a thought about installing the amp in the center console. I would have to make a mount for it I think to keep it mounted securely. If I install it with the adjustments facing up, that would be an ideal location because I could tune it while sitting in the drivers seat.
But again, ventilation.
So there is a little storage cubby in the back of the rear passenger panel with a little cargo net attached. Seems like the sub for EB system maybe goes there?
Could I pop out that little cubby hole, and install a grille cover there?
That way I could maybe install my amp behind the panel but still be able to pop off the grille cover and make adjustments without having to remove the whole panel?
Or maybe I can cut a rectangle out of the forward facing part of the cubby hole to allow access to make adjustments, but make a smaller cover and keep the cubby hole?
Later this week I’ll pull the panel off and see what I’m dealing with.
Is it OK to run speaker wires near the power cable? Or should that be separated too?
Thanks!
sorry for all the questions just want to do the job correctly the first time if at all possible
RCA cables-
Thanks!
