1st gen with 4.10 gears??
matts91XLT
Summerfield Nc
1991 XLT
did they ever make a 1st gen with 4.10s in em? i want to re-gear and if i can find a set of junk yard axels with 4.10s in em it would save me alot!:exp:
FIND
Vermillion, SD
99 XLT V8 AWD
Yes they did, the axle code is D2 for a limited slip, 42 for an open differential. There are actually 3 within an hour from me in salvage yards with 4.10 gears.
klamath Falls Oregon
'91 xlt, 96 xlt
what rig would those gears come from. (the 4.10 gears for ford 8.8)
jd4242
va beach
92explorer&94 ranger
i thought they only came in 2nd gens:dunno:
bats
NY
88 Bronco II
Second gens and early 2000 Rangers irc.
FIND
Vermillion, SD
99 XLT V8 AWD
oh wait, maybe you are right.... I was probably looking for second gen rear ends when I found those... But, the parts search for the salvage yard shows it as an option even for the first gens.... but that might be wrong too.
jd4242
va beach
I know they were an option but very rare.
jd4242
va beach
jd4242
va beach
it was xlt automatic
Sweet.all the ones i ever hear about seem to have been special ordered.i would still swap a 2nd gen rearend in with 4.10 even if i found one with it
Anime
EF YEAH!!
2018 EX Sport Concept
The owners manual for 1st gens lists the 4.10's, and other odd ratios like the 3.08. There have been 2WD first gens found with the 3.08, but none with 4.10's, at least not yet.
Ford may have made a few 4WD's with 4.10 front and rear, but likely not many. My guess would be that the ones that had the 4.10 were 2WD, and so they just had the easily available 4.10's for the 8.8.
Most first gens had either 3.27 (standard) or 3.73 ("performance axle" option) gears.
johnsonhalo
hell hole arizona
92 Explorer Sport 4X4
i'm not sure if it's stock or not, but my truck has a 4.10 in the back. it's a 5speed sport. i find it unlikely that the guy who sold it to me would have been able to successfully swap in a rear axle without breaking something else though.
Naasau
Denver Colorado
'93 Explorer XLT
4.10 rears for first gen 2wd's I have seen in the yards, but I've had a heck of a time hunting down a front pumpkin that is stuffed with them. Maybe one day.
bones66
Bozeman MT
1994 4dr 4x4
i stuffed 4.56 gears in mine. they look massive in the casings but they work great. i think i got them on some mustang website. if i can remember they werent more than 250. and mine is limited slip
L Side View Mirror Compatibility Between 1st and 2nd Gen Explorers? Stock 1991 - 1994 Explorers 8
Rhaegal94 1st Gen Front Shock Mounting Nut Stock 1991 - 1994 Explorers 3
B 1st gen automatic transmissions Stock 1991 - 1994 Explorers 4
RustyMacintosh Sometimes--Good news with 1st Gen Explorer Stock 1991 - 1994 Explorers 4
Exploring XLT 1st Gen Abs sensor replacement Stock 1991 - 1994 Explorers 10
TxCowgirlInCo Very sick 1st Gen: Engine issues, clutch drag & slip.. Stock 1991 - 1994 Explorers 1
I 1st gen 4x4 issues Stock 1991 - 1994 Explorers 2
J 1st gen no more Stock 1991 - 1994 Explorers 5
T 1st gen rear ac addition possibility? Stock 1991 - 1994 Explorers 1
D 1st gen ford explorer, disconnected vacuum lines Stock 1991 - 1994 Explorers 22
davidk 1st Gen Explorer 93 and 94 brochure links Stock 1991 - 1994 Explorers 3
Rick List of Useful Threads Stock 1st Gen Forum's Best Threads Stock 1991 - 1994 Explorers 0
S Has anyone swapped out the front end 4WD for 2WD front endconversion on a 1st gen Ex? Stock 1991 - 1994 Explorers 3
S Aftermarket wheels size question on 1st gen Explorer ? Stock 1991 - 1994 Explorers 12
pteepee69 Solder joints on 1st Gen components Stock 1991 - 1994 Explorers 2
N 1st Gen Poor Fuel Mileage Stock 1991 - 1994 Explorers 22
V Uk based member with 1st gen, help with fault codes please. Stock 1991 - 1994 Explorers 4
T Update on my 1st Gen Purchase... Here is what I bought.. Stock 1991 - 1994 Explorers 17
X 2nd gen rims and 1st gen Stock 1991 - 1994 Explorers 25
P 1st gen catalytic converter Stock 1991 - 1994 Explorers 2
P In need of a 1st gen front bumper!! Stock 1991 - 1994 Explorers 8
S 1st Gen explorers gas mileage and how to increase! Stock 1991 - 1994 Explorers 32
F Spindle nut for 1st gen w/auto hubs Stock 1991 - 1994 Explorers 1
M 1st Gen explorer exterior door handle Stock 1991 - 1994 Explorers 7
L.A.X 1st Gen Gross Polluters? Stock 1991 - 1994 Explorers 15
P My front is bouncing! Is it normal for 1st gen? Stock 1991 - 1994 Explorers 23
L.A.X What else do you drive besides a 1st Gen? Stock 1991 - 1994 Explorers 23
L.A.X Ripped out my stock 1st Gen exhaust Stock 1991 - 1994 Explorers 5
Maniak How To: Change Interior Door Pull on a 1st Gen - Video Stock 1991 - 1994 Explorers 3
O 1st gen Radio problems Stock 1991 - 1994 Explorers 5
M Best Electric Fan Setup for 1st Gen? Stock 1991 - 1994 Explorers 24
D Rusted Gas-hole 1st Gen Only Stock 1991 - 1994 Explorers 3
9 1st gen explorer parking/level warning/bulb check light on dash Stock 1991 - 1994 Explorers 6
Jstcruz Thinking about getting a 1st gen! Stock 1991 - 1994 Explorers 18
P Wiper Blade for 1st Gen: What length? Stock 1991 - 1994 Explorers 8
B 1st gen steering box qestion? Stock 1991 - 1994 Explorers 4
R Should I trade my 2nd gen for 1st gen? Stock 1991 - 1994 Explorers 30
B one piece headlight assembly 1st gen Stock 1991 - 1994 Explorers 9
SwaintaN How to: Hood Pins; 1st Gen Stock 1991 - 1994 Explorers 10
B Windstar seat's in a 1st gen X????? Stock 1991 - 1994 Explorers 2
N 1st Gen Carpet Kit Questions Stock 1991 - 1994 Explorers 12
O Did the 1st gen ever have the rear PDL switch? Stock 1991 - 1994 Explorers 15
B 1st gen Bad body roll and sway!?!?!?! Stock 1991 - 1994 Explorers 8
M Flat black 1st gen? Stock 1991 - 1994 Explorers 28
Y 1st Gen Timing Chain Replacement Stock 1991 - 1994 Explorers 5
E cheap and free modify's to my 1st gen Stock 1991 - 1994 Explorers 15
L How to: Replace 1st gen Brake caliper. Stock 1991 - 1994 Explorers 20
J 1st gen power window problem Stock 1991 - 1994 Explorers 5
F HOW TO:1st gen horn relocation. Stock 1991 - 1994 Explorers 2
F 1st gen bucket seat mod? Stock 1991 - 1994 Explorers 9
Similar threads
