2.3 L 202,000 miles No spark to #3 Inlet side | Ford Explorer Forums
INOV8TN
Salisbury, NC
1994 2.3 L 2WD Ranger
Do I need a whole new coil pack or is there more diagnosis needed before I start replacing parts?
Whoops! Make that *Exhaust* side.
Thanks!
Coil Pack - Diagnose, Repair or Replace
Good idea about the codes. I might learn something useful.
I'm going to go to the parts store and use their tool to get codes.
I am wondering if there's any possibility of repairing the pack to restore the spark to the #3 on the Exhaust side.
Is this a wasted spark system firing two at once? If so why does the 'partner' fire perfectly well.
The engine idles and drives well.
Replaced the Coil Pack - Never saw a Key On/Engine Off code related to the Ignition System. Idle is stronger. The codes (335 & 513) seem to be related to EGR sensor voltage being out of range and Internal Voltage Failure - PCM, respectively. I'm going to chase the 335 first.
