Kept blowing #5 fuse
i recently had a probelm with my turn signal, heater, and reverse lights after burning my way thru 15 tro 30 amp fuses, and finally smoking a wire i started to look into the wiring diagram for possible problems. i honestly am dumb to electrical so i was going in blind with not a clue as to what to do., it started at the firewall junction i cut the wire there i do beleive it was blue and orange ,i after cutting into the wire harness tape not much room there i then checked and found i had turn signal but no reverse and heater, then i looked deeper into the wire,, and on a hunch climbed under the truck with a flashlight an to my surprise there it was a a few wires going to the backup light and found out that it somehow the harness had come in contact with the exhaust, and melted the wires there so after going thru the melted wires i hooked up the wire with a fused wire in case it didnt work, it did i now had reverse lights turn signals,and heater so i spliced the wires that were burnt and w/o insulation with 16 guage wire and rconnrcted everything and it all worked, so if your having problems with blowing the number 5 fuse on a 1994 ford explorer xlt then thats where i would look good luck if you need a diagram let me know i can provide one
