bas99explorer
- January 30, 2012
- gaffney sc
- 99 4wd explorer
99 explorer 4.0 sohc 4 it has code p0720 and 9 o/d light flashing iv tried finding the out put shaft speed sensor but no luck.
The 2nd problem it the. 4 wheel drive turn the switch to 4high it lights up 4 high but no 4wheel drive turn it to 4low it lights up then engages low gear still no 4wheel drive I put the explorer on jack stands put it in 4and high and put it in drive the front spun very slow compared to the rear and I could spot the front drive shaft from spinning with my hand and I took a test light to the wire to the transfercase clutch and it was geting power
