2000 Explore loss of power question. | Ford Explorer Forums - Serious Explorations
swilson
North Carolina
Explorer
While driving down the road the engine will act like it is starved for gas. It will sputter and hesitate. I turn the key off, sometimes a couple of times and then it runs fine. It was doing this once or twice a month. Now it is everyday. Replaced the fuel filter. What could cause this interruption in flow of fuel and that is remedied by switching the ignition on and off.
Time for a new pump
Do a fuel pressure test when it's happening
Time for a new pump
It only happens when I driving down the road. It seems to me that the fuel delivery system is the problem. Why would it be cutting out and be fixed by cycling the key?
Bad fuel pump
Cycling the key turns on and off the pump and it can build a little pressure
My vote is a fuel pressure test when its happening///hot
