dcfd470
- November 25, 2013
- 2000 Ford Explorer
Hi I have a question that has been asked before but I am getting several answers. I need to replace my oil pan gasket and I was told that I did not have to remove the engine or anything else on my 2000. I took all of the bolts out and now I can't get the pan out I guess someone told me a lie. Can I remove the front cv axels and front drive shaft instead of lifting or removing the engine or anything else. It looks like if I remove the cv axels and the 4wd unit It may work? If I knew this I would not have even started this now because of the weather but it is inside on a lift.
