pjfsail
- September 26, 2014
- Location
- High Desert, Southern California
- 2000 Mercury Mountaineer
Now I can quit worrying about the door lock.Your door lock issue is unrelated.
The battery certainly isn’t 18 years old. They almost always have a date sticker on them, or branded into them.
I’d verify fuel pressure, as that’d be my first suspect. Might be worth banging on the bottom of the tank with a large mallet and then re-trying to start it. You could also spray a small amount of starting fluid in the intake while trying starting it. Don’t run it on starting fluid, or use it repeatedly.
The positive cable attachment to the battery is corroded and will be replaced but prevents me from taking the plastic cover off to look at the battery's date of purchase.
Starting fluid, good idea and I understand not to run it but to see if it will run. I'll be back
