84FLH
- February 14, 2016
- 2000 Mercury Mountaineer
314,000 miles on orig engine. Runs, shifts, drives good.
Dashboard coolant temp gauge had been reading dead cold for some time, months, actually. The vehicle never overheated that I know of during that time. So I replaced t-stat last week using Motorcraft t-stat bought from dealer. I didn't know about burping system, so it wasn't done. After replacing t-stat I topped off radiator with 50/50 and drove it all week. Dashboard coolant temp gauge was good all week: needle was about 1/3 way up from "cold". Perfect.
Last night after driving 20 mins on highway I stopped at store. Smelled coolant when I got out of vehicle.. Checked under front of vehicle. Found coolant heavily dripping from radiator drain area (passenger side of radiator). It was all over lower control arm, tie rod end, etc. Checking more carefully, the leak appeared to originate on the plastic side of radiator (passenger side) about 3" from top of radiator. From there it had dripped down to the radiator drain plug, and was blown back onto lower control arm, etc.
I didn't fill the radiator there in the parking lot, even though I had some 50/50 on hand, because I hoped the leaking would stop once coolant level dropped below where the leak appeared to originate from on the radiator. I drove another 20 mins home and looked under vehicle front. Coolant was once again dripping from radiator drain plug area, and again I noticed the leak appeared to originate on plastic part of radiator, about 3" from radiator top.
Could a defective rad cap over pressurize the system and cause massive leaking from what was previously a small leak?
Did not burping system cause/aggravate this problem?
How can I tell if there's any coolant in the engine or radiator?
Will the leaking stop once coolant level is below suspected origin of leak?
Now that it's daylight I'll be looking closer to find exact origin of leak (if possible), and checking oil for signs of coolant.
What else should I check?
I'll be bringing vehicle to shop next week. Maybe at 314,000 miles it's time for new radiator.
Suggestions welcomed!
