2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Front sway bar bushings & links
While working on the installation of my engine oil thermostat I noticed that the left front sway bar link had failed.
I decided to purchase a sway bar bushing and link kit from Energy Suspension. Their website lists my front bar as having a 34 mm diameter. Using calipers to measure the stock bar I got a similar measurement so I ordered their kit (Part Number: 4.5155)
There are two colors available (red and black). I learned from the product description that the black polyurethane contains a graphite lubricant while the red doesn't so I ordered the black. The link design is superior to stock because the outer diameter of the washers is large enough to prevent the grommets from being pushed past them. The link bolts, spacers and washers are heavy duty and should last many years. The bushings have molded depressions to hold the provided lubricant.
Since the bumper was off for relocating my remote oil filters for the engine oil thermostat installation access to the front sway bar mounts and end links was improved from the front. After removing the end links I loosened all four bar mount bolts. I knew that the bar was solid (heavy) and that I was in an awkward position while under the vehicle loosening the mount bolts. As a safety precaution I positioned jacks stands an inch below the bar on each side.
I'm glad that I did because when I removed the second bolt on the passenger side with my right hand I wasn't ready for the weight of the bar with my left hand but the jack stand stopped the bar. If not for the jack stand the falling bar could have broken my nose or caused a concussion.
I removed the old bushings which were actually in fine condition. After installing the new bushings on the bar I decided to press the bushings into the mount using two pieces of plywood and a C clamp.
