newtofords
- May 13, 2010
- Central Pa
- 2001 Explorer Sport
I had my mechanic change the gear oil and put in a gasket in the rear differential because it was leaking. He also topped off the oil in the front one. I got the vehicle back and drove it about 4 or 5 days when it started making a loud metal grinding or gear noise coming from the rear. I took it back to the mechanic and he had it for a few days. He said he was not sure but he thought it was the axle. He said it might need a new rear-end but he did not think the vehicle was worth spending a lot of money on because of it rusting so bad. I agreed.
I had no sounds or problems with the rear-end previously to taking to this mechanic.
The only thing that I have had an issue with previous to this rear end problem is the rear spring on the drivers side has flattened out and caused the vehicle to lean lower on that side. (at least that is what the mechanic said it was) So when I am on a bumpy road it hits hard, like it needs shocks. It also has been slowly rusting away. Running boards are loose and I had some patching done on the divers side. There are holes that need patched for inspection underneath on the passenger side.
The Ford has about 114000 miles on it. Which really is not very many miles. The engine is great, never leaves me sit! I have had it for about 7 years and have driven it on regular roads with no off-roading.
I am wondering if it is possible that something could have happened when he changed the gear oil? I would appreciate any information someone has.
