Norsegod
- July 27, 2015
- 2002 Ford Explorer
I have a 2002 Ford Explorer with the 4.6 V8. I am having issues with the A/C not blowing cold at all. I thought that maybe the coolant was low, so I went out and bought a can of coolant, and hooked it up. I follow the directions on the can and place A/C in Max A/C setting, and fan on high. I hook up the can and what I see is the reading on the meter varies.
The needle will max out at the maximum acceptable reading (in the green) and then drop down to below the green. Then peg back out at the top and drop back down below the green, etc... etc... You can hear the compressor turning on and off with the movement of the needle. So the compressor kicks on when the needle moves up, and kicks off when the needle moves down.
I would like to know if anyone has any idea what the issue could be, as I do not think there is a leak, and it does not seem to be out of coolant. I was thinking that it might be either the high or low pressure switch, but would like to have a second opinion. Any help would be greatly appreciated.
