oldgranola
- March 10, 2013
- seattle
Got the dreaded front windshield washer pump not working. But pump is fine at the bench. Strange electrical diagnostic behavior: probing with a 'power probe' connected to the battery poles and probing the pump connector whilst pushing the washer button on the wiper stick changes one of the washer pump leads from open good ground to +12v (thats wierd to go from open battery ground to positive 12v). The other side of the connector is dead. No ground, no positive. Multi-meter voltage test between the two gives near zero volts even when the washer button is pushed. So...strange circuit and definitely one bad side (dedicated ground?). I just read in the following old thread that there's a kind of figure 8 (H bridge?) that changes the polarity to the pump motor depending on if one pushes the back or front washer button. But I can't find any documentation on what relays-where is this all controlled by.. My Ford explorer Haynes book is confusing.
old thread on washer electrical
yes I do have a destroyed tailgate electrical (dog ate the wiring, seriously!). If the two are linked, is there a best spot to at least put in a ground (temp) for the front washer pump? I'd prefer not to try to splice it in the small wheel well space. Wiring diagrams are great (not really) on paper but I can't find the correct relays and the wires going into, ford 2002 4.0L explorer has poor documentation it seems. Example, I don't find any 'washer' relay or similar in 2002 braker box diagrams
Thanks for helping.
Thanks for helping.
