93nav
- August 25, 2004
- Minneapolis, MN
- 2002 Sport
2002 Sport, Intermintent no start when hot, cranks, no gas smell - UPDATED/Fix$$
2007-09-01
I have a 2002 Sport, 102k miles, stock
Twice in the last week it has not started after going someplace and then after 1 to 10 minutes, try starting, and it just cranks. No smell. I did not notice if the fuel pump hummed at these times or not. Took it to a service station (non-dealer) after the first time, and there were no codes and he could not see anything obvious. Firt time the tank was about 1/8 full, second over 1/2 full. Explorer was fully warmed up when both of these occured. Other times between these two incidents, started and ran fine. Both times when it would not restart, wait 45 minutes, 1 hour, and starts fine. When won't restart, first time to try, it kind of pops a LITTLE, and then after that just cranks.
- I purchased at 59k, I have not replaced fuel filter since purchase, so I do not know when the fuel filter was last replaced.
- Plenty of power
- Good gas mileage, 23.9 and 22.5 within last month when driving in rural areas (like an old lady)
- I tend to not put gas in until 1/8 on the gage, usually 14 +/- gals on a 16.8 gal tank.
- Plugs and wires are original (I assume)
- I use regular gas from name brand stations
- I have never added any 'additives' to the gas
-General question for mechanics, why don't you talk to the customer, owner before starting to work on things? An old proverb: "A problem clearly stated is a problem half solved".
Dealer says they need to replace a checkvalve and a pulse damper in the fuel system. They are both leaking, at least one into the intake manifold, or so says the lady who called me. One or the other is supposed to be integral will the fuel pump. Then need to drop the tank and want $1279 +/- for the whole deal (OUCH!!!!!). I asked about needing to change the oil, is leaking into the intake manifold, not needed/specified I was told.
- What is a pulse damper and where is it at?
- If something was leaking, why did I not smell gas?
Any help or comments/clarifications would be greatly appreciated.
2007-09-01
- Plenty of power
