jcsaathoff
- March 5, 2010
- Bloomington, IL
- 2002 XLS 4 Door 4x4
Hello I have a 2002 Ford Explorer XLS 4 door model with a 4.0 L V6. Since November I have had problems starting the truck. It takes several cranks to start the truck, some times 5-10 mins worth. It has always acted like it does not get fuel. Once it was started it drove fine, and if the engine was still warm it would start right up. It takes a couple hours sitting to "recreate this condition". I took it into the shop to have it fixed and they installed 2 new pumps within 2 weeks, obviously this did not solve the problem. They claim they have no idea whats wrong with it, and they say it started up fine all day today and they have done nothing since installing the second fuel pump. I'm not aware of it throwing any codes.. the check engine light has never come on.. I did the other day watch them try and fix it up when I went to pick it up... key would turn on and it would be 0 psi... 2nd time 30 psi.. no start... 3 time 10 psi no start...
They made mention that there was a TSB out concerning re-flashing the computer for a cold start issue... but they said this would not cause the fluctuation/lack of pressure in the fuel system. They say they tested the Fuel pump relay's and the inertia switch and they were fine?? It seems almost like a thermal problem sometimes (hot engine/cold enigne) but I've parked it in a heated garage and had the problem recreated and its been outside in 40 degree weather and started right up... Also I've had this for 2 previous winters and ALWAYS started up.. until this one...
