shusaka
- May 23, 2010
- Bryan, Texas
- 2003 Exploder Eddie Bauer
There are a lot of things going on so I will try to be as brief as possible. I have a 2003 V6 Explorer Eddie Bauer Edition and here are the things that are going wrong.
1. None of the power door locks work.
2. None of the key fob functions work.
3. The keyless entry keypad does not light and does not work.
4. When you turn off the ignition and remove the key, you are supposed to be able to listen to the stereo and power the windows up/down until you open any door, at which point, the stereo turns off and the power windows are supposed to quit working. But in this case, you can turn off the ignition, remove the key, open any door, and the stereo and windows continue to work.
5. The door-ajar indicator in the dash never appears when any door or hatch is opened.
6. When you open any door or hatch, the dome lights never come on.
7. There is/was a power drain on the battery when everything was shut off.
I found a few wires with cracked insulation, so i did the repair mentioned in previous threads, i replaced the CSM with a brand new unit from ford, still having these same problems, any other ideas on how to fix???
