2003 Explorer rear wheel bearing replacement | Ford Explorer Forums - Serious Explorations
spazik697
muskegon, Mi
03 ford explorer
I need to replace the rear pass. side wheel bearing and can't find a step by step guide anywhere for it. another thing is that the old bearing was so bad that the bearing fell apart leaving just the outer housing in the wheel Hub. What do i do?
I'd probably suggest grabbing a Hayne's manual from AutoZone or similar parts store, or if you want to go one better, check out www.alldatadiy.com and buy a subscription for your particular vehicle. It's about as expensive as one book, but gives you the same information that the repair shops use daily, including step-by-step instructions on just about everything, electrical diagrams, TSB lists, and maintenance schedules.
I could try to walk you thru it, but with the lack of pictures available to post to the web, it'd be much easier doing one of the two things I mentioned.
