2004 Explorer Engine Replacement Cost | Ford Explorer Forums
NickXLT
Santa, Maria
2004 Explorer XLT
Hey all, I have a 2004 Ford Explorer XLT with a 4.0 V6 for 204k miles. I got it from my grandparents at 142k with no problems, around 160-170k it started making the infamous timing chain rattle noise. I have put it off for far too long, so I am in the process of figuring out just how much it will cost to replace/rebuild. I am 99% sure it is the timing chain, only happens when I got above 2,000rpm and cold starts can sound a little scary at times.
I have already replaced the transmission at 189k, but otherwise this thing runs like a champ. I just want to see what the ballpark is that I would be paying for this job to be done. I move to college in a few months and I don't feel like having this hanging over me while I am there. Any and all suggestions are more than welcome.
Where is the noise? Front of engine or back?
The timing cassettes and tensioners can be replaced in the truck on the front
The back the engine must come out
I'm pretty certain it is the back of the engine. I am not 100% sure, but even if it was the front cassette, I would want the rear replaced so I don't have to worry about that breaking. Do you think it is worth it to replace to just replace the cassettes, tensioners, and chains? Or at that point do I just do a replacement/rebuild.
I would like to replace all the rubber hoses as well, some of them have seen better days.
Sohc engines are very tough
Their weak spot is the timing chains guides and tensioners
With a good running sohc that is just noisy, usually we can get away with pulling the engine and doing a “refresh”
This would be a full tear down and rebuilding all new gaskets, tune up parts, oil pump, and all timing components
That is all they usually need
However a compression test before pulling the engine is the way to determine if you can re use your engine or not
Many of us can do this sort of thing in a 5-7 day timeframe given the parts are here and tools available. If it’s your first time pulling an engine and re stabbing it then it can take longer
Cost anywhere between $800-2000 depending on parts used
The guides can be broken and not make a sound. Then, seemingly out of no where, poof, the engine is shot.
If you have an engine stand, cherry picker and some time, this is a job you can do yourself.
I have a 2004 Explorer with the 4.0 and at 205K it broke a piston ring land. I put a used engine in it and while it was out I did the chains and cassettes. I was quoted almost 40 hours labor to remove and replace the motor and "refresh" with heads rebuilt and short block piston and rings and bearings. At their labor rate of $85 per hour (lower than most) it would've been $3500 in labor alone. Total was expected to be around $6K. The used motor cost me $2K and it had 90K miles. The chains and cassettes were still good but I changed them anyway since it was out. I did the engine r&r myself and around $250 in parts. I didn't replace all of the hoses but did the major cooland hoses and the water pump and t-stat. I probably wouldn't do it again. They are easy to buy the whole vehicle running for less.
