2006 4.0 Rear Hub/Bearings | Ford Explorer Forums - Serious Explorations
Bobmbx
King George, VA
2016 Explorer Platinum
If I purchase a rear wheel hub/bearing assembly with the bearing installed, do I need to press anything?
It looks like once you remove the axle nut, the hub just slides off much like the front wheel bearing.
Or am I having a fantasy?
Never mind. I'm not doing it. Watched a couple of videos; this is not for me.
It's a couple of hours job. I removed the knuckle and took it to a shop with a press, then they swap the bearings and then I take it back home and put it back together.
The fronts are way easier.
Yeah, I did the fronts, but the rears were out of my zone, so I had someone do it.
