2006 Explorer questions? help... | Ford Explorer Forums
F SANE IL
Brooklyn, NY
2006 Explorer EB V6 4x4
I've got questions piling up and was hoping someone can help clear them up for me. Don't know if I should be asking then individually, just figured I rather not clutter the forum with my junk. So here goes.....
On my 2006 Ford Explorer Eddie Bauer
Does the spare have a TPMS sensor?
Where do I find the door keypad code? (The 2000 Explorer had it in the trunk)
Are there pre-wired connectors somewhere under the seat for heated seats?
If I get the OEM navigation unit, do I need OEM nav antenna or aftermarket or should I just get an aftermarket double din unit and call it a day? If aftermarket, which one?
Don't want to pile up too many things, I think I'll post axle or other related things separately in case someone searches for them.
Thanks in advance!
No TPMS on the spare tire. As far as a navigation unit, I would go aftermarket since the aftermarket units are much more advanced than what originally came with the vehicle. Check the audio/navigation section... lots of info posted over there.
Thanks. I'll check out that section.
