Mr. Q is right regarding the much better reliability of the 6R transmissions in the 2006-2010 Explorer/Mountaineer 4.6L 3V V8 models. However, the 2006-2008 models have the 6R60 six speeds and the 2009-2010 models have the 6R80 six speeds. The main difference between the two is the 6R80 has a slightly higher torque rating. IMO, this doesn't mean much in regard to reliability between them, if anything at all. The 2006-2010 4.6L V8 models arguably have the most reliable engine/transmission combination in any Explorer to date. Just make sure to drop the transmission pan, replace the filter and refill. Then after a 2k-3k miles drop the pan again and refill. No filter change is needed on the second service. This will replace about 75-80% of the transmission fluid and should give you many more miles of longevity if you do subsequent pan drops, filter changes and refills every 40k-50k miles thereafter. I also recommend oil changes using 5W30 synthetic every 3k-5k miles. The one thing I would consider when buying any used car of this age is where it has lived its life. If it has been in areas where the roads are heavily salted in the winter then you should thoroughly check it out for rust damage. Vehicles with excessive rust can be nightmares to maintain as time passes.
