shamski
- May 25, 2010
- Sherwood Park, AB
- 2010 Sport Trac Adrenalin
I have an issue with my 2010 Sport Trac's drive seat ... the up/down for the front of the seat has stopped ... thankfully at an OK height. it is getting power as you can hear the motor engage when the switch is pressed, but no movement. I am guessing the gear is shot.
I have a potentially easy solution -- my predecessor to the Sport Trac was a 2006 Ford Explorer Limited that I still have around (for parts you know ). I have looked at the part schematic and the seat tracks look identical with one exception -- my Explorer Limiter had the memory module and the Sport Trac does not.
I believe the part numbers are:
Sport Trac:
6L2Z-7861711-DR
Explorer:
6L2Z-7861711-ER
The question: can the seat track have the memory module, and work in the Sport Trac?
I could try it out but thought I would ask first.
If it doesn't work out, the search for a used on begins but since it isn't urgent will wait until it is nice out to go looking.
Thanks in advance,
Kevin
Sport Trac:
6L2Z-7861711-DR
Explorer:
6L2Z-7861711-ER
Thanks in advance,
Kevin
