2007 Explorer v 6 various warning lights | Ford Explorer Forums
Markfnc1
Garner, NC
2023 Explorer XLT
My 2007 Explorer has 278,000 miles. I use it on weekends (just got a 2023 a little over a month ago). I was going to the recycling place Saturday morning. My traction control light came on. I pushed the button to see if i had hit it by accident. it stayed on. soon after my temp gauge went to zero like it wasnt working, soon followed by the check engine light. I made it to recycling and then home. When i got home i checked the coolant and oil both ok. doing a quick look online, do you think both the traction sensor and temp gauge both went out at nearly the same time? Did temp going to zero, cause check engine light to come on? Any ideas/help appreciated.
Try to check error codes first
Both HS and MS CAN lines codes checked?i mean ,are you sure your scanner have the ability to read the both of the lines?
Unfortunately,I am not familiar with this one.
There is no such a traction sensor.
Anyway
With not RSC codes ,check the wheel speed sensors at diagnostics equipment (rotate each wheel separately ) and visually. verify the YAW sensor parameter and calibration.RSC wont turn the light on without slipping otherwise there is code stored at car memory ,probably your scanner not capable to read it.
Coolant temp sensor low means the harness or the sensor are bad ,nothing to do with the traction
