relentless85
- January 25, 2015
- Oklahoma, OK
- 2017 Explorer Sport
I’m having trouble pin pointing a whirring sound coming from the front of my 08 Explorer 4x4.
I can hear the wirring sound while driving. It gets a lot more noticeable when I am driving and I turn the steering wheel to the right or make a right turn. It sounds like it’s coming from the driver side area. When I make a left turn or turn the wheel to the left, I do not hear the wirring sound. This leads me to believe it’s on the driver side somewhere?
The driver side cv axle shaft and wheel bearing assembly has been recently replaced with in the last 2 years. Also the driver side seal on the differential was replaced too. Sway bar link ends have been replaced and bushings too.
Driver side lower ball joint was also replaced this year.
So, basically mostly new parts on the driver side. Front diff fluid was drained and refilled with the recommended gear oil.
I don’t know what else to look for or check now. Unless it’s on the passenger side or possibly the wheel bearing/hub has already gone bad on the driver side I replaced? I used a timken brand assembly for replacement on the wheel bearing and hub.
Any suggestions?
Any suggestions?
