2010 ford explorer idling issues code 0401 | Ford Explorer Forums - Serious Explorations
Jai806
Amarillo Texas
2010 ford explorer xlt
I have a 2010 ford explorer with intermittent idling issues and engines occasionally shutting off at idle I’ve replace fuel pump. Evap sensor, throttle body Egr coil pack spark plug wires crankshaft positioning sensor intake manifold gaskets upstream and downstream o2 sensors fuel filter and tested mass air flow sensor and had the pcm checked and it seemed to be responding also had a compression checked and it came back fine..any other suggestions??
