So if my wife, while driving her explorer losses power steering assist and crashes, my response to her will be: "hey honey, sorry you don't have sufficient upper body strength to maneuver a mechanical steering system, but you did get an audible/visual chime alerting you of this condition"
""STEERING
Your vehicle is equipped with an electric power-assisted steering (EPAS)
system. There is no fluid reservoir to check or fill.
If your vehicle loses electrical power while you are driving (or if the
ignition is turned off), you can steer the vehicle manually, but it takes
more effort. Extreme continuous steering may increase the effort it takes
for you to steer. This occurs to prevent overheating and permanent
damage to your steering system. If this should occur, you will neither
lose the ability to steer the vehicle manually nor will it cause permanent
damage. Typical steering and driving maneuvers will allow the system to
cool and steering assist will return to normal.
The EPS system has diagnostic checks that continuously monitor the
EPS system to ensure proper operation. When a system error is
detected, the following message SERVICE POWER STEERING, SERVICE
POWER STEERING NOW or POWER STEERING ASSIST FAULT may
display in the message center. Refer to the Message center in the
Instrument Cluster chapter for more information.
WARNING: The EPS system has diagnostics checks that
continuously monitor the EPS system to ensure proper operation
of the electronic system. When an electronic error is detected, the
message POWER STEERING ASSIST FAULT will be displayed in the
message center. If this happens, stop the vehicle in a safe place, and
turn off the engine. After at least 10 seconds, reset the system by
restarting the engine, and watch the message center for POWER
STEERING ASSIST FAULT. If the message returns, or returns while
driving, take the vehicle to your dealer to have it checked. With the
message displayed, the steering assist is turned off, making the vehicle
harder to steer.
"WARNING: Fail-safe mode is for use during emergencies only.
Operate the vehicle in fail-safe mode only as long as necessary to
bring the vehicle to rest in a safe location and seek immediate repairs.
When in fail-safe mode, the vehicle will have limited power, will not be
able to maintain high-speed operation, and may completely shut down
without warning, potentially losing engine power, power steering assist,
and power brake assist, which may increase the possibility of a crash
resulting in serious injury."
At least you're in a larger vehicle and have a little more safety. Remember the Pinto??:thumbdwn:From what I was told by Transport Canada, steering is one of the major components that MUST be working flawlessly or it is considered a hazard. If ford has identified that racks made between date A and date B may fail they MUST recall vehicles with these racks.
Ford made my damn death trap. Ford should be helping me - just the way it helps my fellow customers south of the border.
I don't think this matter is finished.
Ford's economic calculations in fighting a recall are based on a static assumption of 2.5 failures per 1000 vehicles
Thats great news Matt! Congrats!![]()
I appreciate your recommendation, Matt.Thanks...Cory really started the ball rolling. Make sure you send him a PM...
can you explain why Ford wouldn't send the same information to its dealers who are genuinely trying to help their customers?
...it's called "containment"....
It was a manufacturing defect with potential for life threatening results in a critical component.
