jmr061
- August 24, 2014
- Wisconsin
- 16 Exp Sport
If there was, I would like to know about it!
Thank you
All TSB with ODOR in it:
TSB
13-9-18 3.5L TI-VCT - FOUL ODOR FROM COOLING SYSTEM - BUILT ON OR BEFORE 7/9/2012
Publication Date: September 20, 2013
FORD: 2012-2013 Explorer
The article supersedes TSB 12-8-8 to update Service Procedure and Part List.
ISSUE:
Some 2012-2013 Explorer vehicles equipped with a 3.5L Twin Independent Variable Cam Timing (Ti-VCT) engine and built on or before 7/9/2012 may exhibit a foul, rotten-egg type odor coming from the cooling system or components, typically after coming to a stop with the climate control recirculation door in the fresh air mode.
TSB 15-0096 2.0L ECOBOOST - FUEL ODOR
Publication Date: June 10, 2015
FORD: 2013-2014 Edge
2013-2015 Escape, Explorer, Focus, Fusion
LINCOLN: 2013-2015 MKZ
2015 MKC
ISSUE:
Some 2013-2015 Escape, Fusion, Explorer, MKZ, Focus ST and 2013-2014 Edge and 2015 MKC vehicles equipped with 2.0L EcoBoost engines may exhibit fuel odor originating from the positive crankcase ventilation (PCV) hose.
SSM 45053 - 2007-2015 Various Vehicles Equipped With All Wheel Drive - Propane, Or Natural Gas Odor During Idle Or Low Speed Driving
Some 2013-2015 MKZ vehicles equipped with a 3.7L, 2007-2014 Edge, 2007-2015 MKX, 2011-2015 Explorer, 2009-2015 Flex, 2010-2015 MKT, 2008-2015 Taurus, 2008-2009Taurus X, 2009-2015 MKS, 2007-2012 Fusion/MKZ, and 2007-2011 Milan vehicles equipped with a PTU may exhibit a propane, or natural gas odor from the HVAC systemafter driving the vehicle for 20-45 minutes. This odor, if present, is most noticeable while idling or during low speed driving. Inspect the PTU for fluid leaks and repair any leaks per Workshop Manual Section 308-07B. If odor is still present after the leak repair and cleaning, replace the PTU and vent hose, if equipped. For vehicles with no leaks and odor present, replace the PTU along with thePTU vent hose, if equipped. Refer to Section 7 of the SLTS manual for the appropriate labor operations.
TSB 14-0130 EXHAUST ODOR IN VEHICLE
Publication Date: July 22, 2014
FORD: 2011-2015 Explorer
This article supersedes TSB 12-12-4 to update the vehicle model years and Service Procedure.
ISSUE:
Some 2011-2015 Explorer vehicles may exhibit an exhaust odor in the vehicle with the auxiliary climate control system on. Customers may indicate the odor smells like sulfur.
