steve721
- April 26, 2017
- 2012 Explorer Limited
My daughters 2012 Explorer Limited seems, like every so often, more and more often, the brakes are sticking or something. after braking to stop then a death wobble at moderate speeds the truck seems to want to stop like the brakes are sticking. i have had a good mechanic replace the 2 front struts, the two front tires and i replaced the inner and outer tie rods and also went all the way around it with front brakes and rotors. also new rear brakes. i even cleaned the rotor brackets so the brakes could slide and not stick. also had another mechanic replace the 2 front brake lines. he said they were collapsing. i'm lost! HELP!
