seancon1
- November 27, 2022
- PORT CHARLOTTE
- 2012 Explorer Limited
I purchased a good running used 2012 explorer limited with the CEL light on, only code has been p0446 BUT the fuel guage would only read 1/2 tank (a possible cause in some searches). Dropped the tank and found 1 sending unit had a broken wire. Replaced both sending units and guage works normal. DTE always was accurate from 1/2 tank to empty. P0446 is still present. Replaced the purge valve under the hood and still has p0466. Not much in this forum for 2011 up with this code other than
Dorman shows 2 parts
911-535
Vapor Canister Vent Solenoid, 2012 does not seem to have this although its listed as "fits"
911-222
anyone have any thoughts?
Sean
- Missing Fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Vent control valve harness is open or shorted
- Vent control valve circuit poor electrical connection
- Faulty vent control valve
911-535
911-222
Vapor Canister Purge Valve, Replaced with motorcraft part.
Sean
