LarryD2013EXP
- May 6, 2015
- Location
- North Carolina
- HENDERSONVILLE,NC
- 2012 Explorer, Limited
Hello. I have a 2012 Explorer that has been having a check fuel inlet message. As well there is a code P0457 (fuel cap loose or missing)
obviously there is no fuel cap as it has the cap-less Fuel filler.
I have checked the purge valve and it’s working fine.
I assume it is a problem either the seal around the fuel filler. I have cleaned it with carb cleaner and compressed air and lubricated it with wd40.
I have searched online for the parts to replace the seal and have not found anything.
has anyone else experienced this issue and know where I can just purchase the replacement seal ?
and posit he procedure to replace it?
