AlexBanich
- December 22, 2015
- State College, PA
- 2012 Ford Explorer XLT
Ok so have an xlt that has had an ongoing problem. It started this whirring sound, so having 120k miles I figured wheel bearings maybe tires. So I got wheel bearings and installed them. Didn't fix the problem. Took it to the garage and they said it had a bent strut. So they change the struts and the shocks cause it needed done. They also did an alignment and re balanced the tires. They said they had to make some alignment adjustments and add a little weight here and there. So it was slightly better but then it started this shaking not too soon after. I take it to another garage who says then alignment is good and they just start from scratch to rebalance the tires. Once again everything seems all but fine. Still a little bit of a shake and whirring but nothing crazy a week later wife says it's so bad she can't drive it over 40mph. So I decide I'm going to put it on jack stands and see if I can locate the problem. Do this and discover that there sounds like a low level whirring in the front and equal driver and passenger side at the wheel well. Then the driver side tire locks up and when I hit the brake it clunks. So my question is this all cause by a failing front differential? I had one go in a trailblazer that whirred till it shattered but not shake the car like crazy. Not saying that its impossible. Just figured I'd ask before I spend the money for the repair. THANKS
