giantsfan
- January 26, 2010
- California, MD
- '14 Explorer Limited
Hi Everyone! I have a '14 Explorer Limited 3.5L AWD with 61,000 miles that is causing me major issues. I have had a major vibration on the passenger side of the truck at approximately 1400-1800 RPM at any speed. This happens while driving or when I try to duplicate it by 'power braking' the truck. Once it's in park or neutral without a load I can't duplicate the vibration. It's very loud and the whole passenger floor board vibrates in that RPM range. I can even feel it in the shifter and gas pedal.
Here is a list of everything I have done so far to try to fix it:
- Replaced RH wheel bearing: still had vibration
- Rotated tires: Tires are 3 year old Michelins with plenty of tread, still had vibration
- Attempted the PTU flush (the gear oil was nasty and smelled to high heaven!): still had vibration
- Replaced the PTU: still had vibration
- Replaced front brake pads and rotors: still had vibration
- Replaced front RH caliper: noticed that the pistons were not moving fully, still had vibration
- Replaced transmission mount: still have vibration.
The transmission mount I just replaced today. I replaced all the other thing in the last couple of weeks and I'm pulling my hair out trying to figure what is causing this! My wife is actually scared to drive it because the vibration is so bad.
If any of you have any other ideas that I might have missed or know what this could be I really appreciate it!
Thank you!
Thank you!
