SHUMAX
- December 30, 2002
- Ohio
- 2019 Explorer Sport
2014 Sport with 108,000 miles. When I slow down from 60+mph, the transmission shifts harshly on the downshift at 40mph. Also, if I am cruising around in a parking lot at low speeds - 10mph, as an example, and it's in first gear and then shifts to second, it's rough.
In both cases, you can "feel" the transmission moving around in the car - it jars it just a bit and makes a mechanical clunk noise.
I had the fluid changed 20k ago and there was no real change. It was in for another item and the dealer claims they updated the computer on the tranny. I also did the disconnect on the battery with no improvement.
It feels like the mounts are loose, for one. From there, something is just "off" and causing it to jump into the next gear too quickly rather than smoothly. The dealer claims the mounts are solid, though.
Any thoughts?
Shumax
Any thoughts?
Shumax
