Havfun
- May 27, 2012
- 2010 Explorer EB
2010 Explorer EB, 4.0L V6, 151k miles. No troubles with transmission until today. Powertrain Wrench symbol appeared on dash and shifting into reverse and into 4th (or 5th maybe??) became harsh. Also, the OD light stays off and does not come on when the OD button on the shift lever is pressed. Have codes P0798 and P0968 but no Check Engine MIL light. I did a complete fluid change 11k miles ago and the pan was immaculate. I visited this thread:
https://www.explorerforum.com/forums/index.php?threads/overdrive-light-not-working.473300/ - post-3722539
And it sounds like my problem is reported in that thread.
So, now for my questions:
- Should I first check anything else or am I good to go forwards on replacing the solenoid Pack?
- I hear references to updated versions of the Solenoid Pack. Does my 2010 include the updated version in the originally supplied part or did the update come after the 2010 Explorer production?
- The two trouble codes both pertain to the Pressure Control Solenoid “C.” Is it possible to replace this solenoid separately from the entire Solenoid Pack or is this not available separately?
- Any recommendations on where to purchase the Solenoid Pack (or the “C” solenoid)?
