SuddenTrouble
- September 13, 2023
- Epping, NH
- 2016 Explorer 2.3
Hi there, new to the forum and havent really searched around a whole lot.. figured id come right out and ask maybe you guys can point me in the right direction...
p1016 wastegate pressure higher than expected also has the shudder at certain speeds under accel- i replaced the MAP sensor and control solenoid and all seemed well for a little bit but now the codes back on and still shuddering, im going to check the actuator arm and see if theres any oil on top of the turbo. going to do a trans drain and fill and filter also. any ideas on what i should be looking into next?
