- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Oh boy, who has a picture of the engine bay to show where they are?
The AC lines have the pressure switches in them. Without a picture or diagram, the compressor is usually the place to trace the lines from. On each line if you follow it will be a small device with an electrical connector going to it, two wires. The lines go into the firewall of AC box outside of it, or the drier back there, the evaporator(or two) are inside the dash etc. The AC signal/trigger wire is going from the dash AC controls, through the firewall, to each pressure switch, and finally to the compressor relay which you have been working at. Somehow that signal isn't reaching the relay, or the AC control isn't producing the proper signal.
Someone with experience with the AC on the 5th gen's might chime in soon, with details about where the components are. A shop manual has everything of course, but people hunt on forums to solve problems they don't want to pay big money for a manual, or go to the dealer either.
