2016 XLT Blower Motor | Ford Explorer Forums
whadeduck
Estero, FL
2016 Explorer XLT
Weird thing. The blower fan works sometimes. No pattern. Is it the resistor, the motor or the controller?
Okay, now it will occasionally start blowing air and then just fade off to nothing again.
Dealing with same on 2013 model. Did some research and ordered this:
9L3Z19E624B Blower Speed Motor Control Module/Resistor Oem Ford, With Atc Amazon product ASIN B004K8V6XS
Hoping this does trick, looks pretty easy to replace (famous last words)
I ordered that and the fan motor itself. I replaced them both last night and everything seems to be working again. I just figured I might as well replace them both while I'm down there. What sadistic person put that third screw in the sound deadening panel? Oy!
Can you be more specific so I am not doing a lot of cussing when my turn?
This video helped a LOT.
This one for some supplementals:
The three screws on the panel under the dash are 7mm. Everything else is 8mm. However, you do need a 3-inch extension and a deep-well 7mm socket to get to the back screw on the under-the-dash panel. Mine is a 2016. So yours might have some differences. Everything is a LOT easier once you get the under-the-dash panel off. Much better access to everything then.
I now see what you mean. Had i not known what i was dealing with, i am sure i would have busted it. Getting that hidden screw back IN was no picnic either. I replaced controller, so far so good, crossing fingers
