2017 Explorer sport cold air intake issue
Mlim_556
Northern MA
2017 Ford Explorer Sport
I have a Windstorm cold air intake installed in my 2017 sport. It makes a weird popping noise when accelerating. It doesn't matter if it's full throttle or gradual acceleration. It happens low speed as well as highway speeds. Anyone experience this noise on an aftermarket intake?
Magnetic619
San Diego, CA
Is it a swoosh popping sound? From the BOV's?
Mlim_556
Northern MA
I don't hear a swooshing noise, just popping. I doubt it's the bov because it'll do it when I am feathering the throttle, or increasing speed gradually
Magnetic619
San Diego, CA
Any check engine lights? Is the IAT sensor plugged in?
Mlim_556
Northern MA
No check engine lights, and everything is plugged in
rhaviation
Huntsville, Alabama
2016 Explorer Sport Black
Callsign
Viper-6
I have also noticed this just recently. It’s almost like a slight thump or thud barely audible but also seem to feel it in the gas pedal. Have to have all audio off, ac off and easier to hear/feel when the windows are up since the boost and intake sound tends to over ride the new noise.
MagneticCharm
Cincinnati, OH
2015, Explorer AWD, XLT
I can't imagine what could be 'popping' in the Windstorm CAI unless you have something 'odd' inside of the tube or filter. Have you taken it back off to make certain there is no cardboard/plastic packing type material? If I had to guess the noise/thumping is coming from something else. Did you keep the factory intake? I would suggest swapping it back and seeing if the noise/thud goes away.
Mlim_556
Northern MA
you are dead on..I still haven't figured out what it is yet
Mlim_556
Northern MA
My factory system has been on, and it only does it with the CAI. It's nothing on my part, for some reason the CAI is causing this noise.
MagneticCharm
Cincinnati, OH
Can you replicate it without driving it? Get a friend/significant other to rev it while you listen with the hood up. Hold the tube, place your hand on the filter box etc?
Mlim_556
Northern MA
The sound only happens when i'm driving
rhaviation
Huntsville, Alabama
Callsign
Viper-6
I too agree that I have only been able to replicate it while actually putting the vehicle under a load driving. I’m going to have to try putting my OEM filter back on also to check.
rhaviation
Huntsville, Alabama
Callsign
Viper-6
Do you have any of the other Livernois kit installed or tune? I have the 93per tune, down pipes, 3 BAR MAP, thermostat, and Borla Cat Back and CAI so I’m concerne going back to my OEM filter while modded.
Mlim_556
Northern MA
I'm tuned with a 3 bar, and thermostat. Swapping out your intake won't do anything to your vehicle fyi, It's safe to use the factory or aftermarket intake
FlipSavage
Glendale, AZ
2017, Explorer Base 4wd
You might check the mounting of the aftermarket CAI. i have found on past vehicles that some do not mount solidly to allow "flex" when the engine moves causing a thud/thump sound that is not consistently replicated. This could also explain why you feel it when it happens.
rhaviation
Huntsville, Alabama
Callsign
Viper-6
I tried physically moving anything in the area even around the new CAI, to include lines etc that might be flexing or knocking together. Even so far as to zip tying lines that are movable. The only major discrepancy I can see is the front of the intake where air comes in sits higher it appears. This troubleshooting has actually got me puzzled.
FlipSavage
Glendale, AZ
if it sits higher in the front could it be getting interference from the hood when it is closed?
rhaviation
Huntsville, Alabama
Callsign
Viper-6
Highly doubting it. I tried a chalk/baby powder on the tall seal around the top of the air box and even it’s not showing any contact but the front lip in the grill area could be something hhhmmmm.
SJExplorer
Philly Burbs, PA
‘17 Sport
Is it a distinct "loud" pop? If it does it under load, when pulling your foot off of the gas quickly, it could be the throttle plate in the throttle body slamming shut. The lack of a resonator with the new intake is going to make any intake noise more pronounced. Someone mentioned blow off valves, but factory engines have diverter valves, not BOVs. (They both prevent compressor surge, but vent differently) They don't vent to the atmosphere. You could also be hearing the diverter valves actuating.
Chris Kauffman
Felton, Pa
2016 Ford Explorer Sport
Your not alone. I started hearing the pop noise at part throttle too when I installed the intake. Not loud, really only notice it if the radio is off. I put the stock setup back on and it goes away. So I’m sure it normal, just the windstorm makes it more noticeable.
