- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
"The 2020 Explorer is expected to share a platform with the new Lincoln Aviator. That means it will most likely be rear-wheel-drive based, with all-wheel drive available as an option. The CD6 platform was also designed to accommodate front-wheel-drive layouts, but we don't see Ford going that route with the new Explorer. That's because a teaser image Ford released shows an SUV with a longer dash-to-axle ratio, suggesting the engine will be mounted longitudinally. Proportions also appear to be similar to the rear-drive Aviator concept (pictured above), with a sloping roof and a pronounced beltline."
"Ford hasn't said much about the new Explorer, but we do know one thing for sure: There will be an ST version. Like the Edge ST, the Explorer ST will most likely replace the Sport model. Currently, the Explorer Sport makes 365 hp from a 3.5-liter twin-turbo V-6, but we expect Ford to add a good bit more power, potentially pushing it past the 400-hp mark. Look for the Explorer ST to get a rear-biased all-wheel-drive system, as well as a sport-tuned suspension and active roll control. Hopefully, it will offer enough performance to give the Dodge Durango SRT a real run for its money."
2020 Ford Explorer: What to Expect From Ford’s Redesigned Family Hauler - Motor Trend
