Does it work if you turn the 4 way flashers on?Hi ... My rear left LED has stopped working ... Right LED is working fine .... Though both LEDs right and left work fine when at applying brakes ..
Yup, it has to a circuit issue.Time for a dealer visit.
Thanks , let me go ahead and try thatYou could try to unplug the connector and reseat it. Beyond that, I would take it to the dealer
Unfortunately no , it works only when I apply brake
4 way flasher Orange bulbs working perfectly fine
I would keep a close eye on it. If you take it in while it's working I would guess they can't fix it because they can't duplicate the issue. And if it happens again take it in ASAP. Even if they can't work on it then they can see that it is an issue. Good luck with it.Thanks , let me go ahead and try that
Update: switched headlight switch from auto to manual and back to auto , everything came back to normal , rear stop lamp turned on and working
Seems like a malfunction to me
That is something that can happen with certain mods. From what I read about that 'Act' there are some exceptions to warranty coverage.So my dealership claims that Ford is denying the warranty claim because I don’t have “Ford bulbs” for my turn signal and reverse bulbs. I guess they don’t know about the Magnuson-Moss Act.
