aldive
Elite In Memoriam
- January 17, 2001
- 1999 XLT
The data is from my '99 SOHC using Amsoil Bypass filtration ( Dead Link Removed ) and Amsoil Series 2000 0W30 ( Dead Link Removed ). The mileage on this oil sample is 24,682 miles.
No oil filters were changed and no make up oil added at this sampling.
The UOA on all the samples was performed by Blackstone Labs ( Dead Link Removed ).
The first ( of 6 ) column represents the virgin oil ( VOA ), the second is a previous sample of this oil at 5120 miles, the third is another previous sample at 7679 miles, the fourth is a sample at 19,848 miles, the fifth is the current sample and the last represents Blackstone’s average of data collected for this type motor.
Aluminum 0 2 5 6 8 5
Chromium 0 1 1 1 2 1
Iron 2 8 14 23 31 16
Copper 0 5 9 8 10 6
Lead 0 2 5 4 5 4
Tin 0 0 1 1 1 1
Molybdenum 0 4 7 10 10 43
Nickel 0 0 0 1 1 0
Manganese 0 0 0 0 0 1
Silver 0 0 0 0 0 0
Titanium 0 0 0 0 0 0
Potassium 0 0 0 0 0 2
Boron 64 31 28 15 14 47
Silicon 4 5 7 13 13 9
Sodium 0 1 2 3 5 18
Calcium 1722 2054 2176 1907 1949 2039
Magnesium 598 751 831 525 567 202
Phosphorus 822 935 879 736 753 748
Zinc 958 1081 1021 875 1003 893
Barium 0 0 0 0 0 1
TBN 12.0, 4.9, 3.3, 2.3, 2.0
This sample Typical Amsoil 0W-30
Viscosity @ 210degF: 71.3 56-64
Flashpoint in deg F 410 385 >395
Fuel% < 0.5 <2.0
Antifreeze% 0 0.0
Water% 0 0.0
Insolubles % 0.4 < 0.6
Blackstone's comments:
AL: We are impressed. You ran this oil 25,000 miles and while wear read high, it's not excessive. Note the viscosity, reading in the 15W40 range. The TBN was 2.0, some active additive left but not much. 1.0 is considered too low. Wear metals increased, as expected with the longer oil use but none are in the caution range. Silicon has increased over previous levels and could show it's time for a new air filter. Oil filtration was okay. But overall, things look good. If the higher (and somewhat abrasive) wear metals don't bother you, try adding a few thousand miles & check back.
My conclusions:
This UOA validates extended OCI using bypass filtration. Even though this oil is still “good” and I could get more miles out of it, but based on this 25k UOA, especially the thickening of the oil to 15w40 and my quest for mileage, I shall change the oil and filters soon and go for another 25k miles ( with UOAs ). I will continue to use Amsoil Series 2000 0w30 oil and Amsoil EAO filters ( both full flow and bypass ).
This motor, with 119k miles, has never used any oil whatsoever.
Copper 0 5 9 8 10 6
Lead 0 2 5 4 5 4
Tin 0 0 1 1 1 1
Nickel 0 0 0 1 1 0
Silver 0 0 0 0 0 0
Sodium 0 1 2 3 5 18
Barium 0 0 0 0 0 1
Fuel% < 0.5 <2.0
Antifreeze% 0 0.0
Water% 0 0.0
My conclusions:
